Modem7 said:
> Note that the schematic that shows the physical layout of pins on the large DIN connectors is wrong.
> The correct wire-to-physical-pin assignment is at:
Yes, after a bit of initial hair-pulling, I figured that out. Similarly the PS/2 socket is numbered wrongly. I guess whoever created the library templates numbered the pins incorrectly.
Regards, Bob Devries
When I saw Bob's first post, I figured that he was using one of the schematics, and that a schematic error may be a possibility (even though the circuit is quite simple). I compared the schematic to one of my assembled PCBs and the only schematic problem I found was the physical layout of pins on the DIN connectors.If you see any errors in the schematic that result in a broken board, misconnected pins, or other defects please *please* let me know so I can make adjustments to the design. Especially anything involving VCC and/or GND as that is particularly bad news for anything TTL. Please independently verify the PCB circuitry and post your results so future readers are clear as to the AT2XTKBD PCB status.
No, Chuck,
I'm still getting nothing at the output.
Yes, the schematic is in KiCad format.
Um, did you see my latest posting on newer firmware. You now have the option of passing or filtering out the E0 codes.
While I'm here, is there any way to test the jumper "E0" mode on/off on a standard US keyboard to make sure that both the PIC is programmed correctly and the resistor patch between PIC pin 1-4 is done correctly?
