Desperado
- Joined
- Nov 25, 2017
- Messages
- 6,827
And a Merry Christmas to you too ilpaninaro.
Is the dark brown screen actually coming from the Atari 800XL or not? What do you get on the screen if you turn off the Atari in this mode?
The 800 XL has a self test mode (see section 2 of http://classiccomputers.info/down/Atari/Atari_800XL_Field_Service_Manual.pdf). Will it even go into self test mode at all?
If your 800XL has it's main chips socketed, you should try re-seating all of them. If you are using the original Atari power supply it would be wise to check it as well.
I will have another look at the weekend if that is OK.
When looking at U2, did you see anything with a pulse?
Dwight
