ATI VGA WONDER 16 Looking for software or solution
psbsp
I have looked quite a few days now with no result so am reaching out here. Forgive me if this is covered somewhere... and PLEASE direct me to where. Purchased this card hoping to have simple autoswitching but it seems to be emulating mda on a vga monitor. without the software I'm not sure how to switch modes. I tried the xl driver that seems to be commonly available but am given an error that no ati card is in use. I am using a sony vga from 1996 if perhaps there is a compatibility issue there. 5170. any guidance would be greatly appreciated. Hope it's something simple that Im just missing. thanks.
I will try this tonight, but I believe it is the same driver I've tried. thanks! will post image of card if no luck.
No luck. image of card attached. error message is:
"This installation doesn't support the video card(s) in your system. Please use ATI or ATI-compatible hardware."
message is displayed in what appears to be mda emulation using the card.
I have one just like it and it works fine. May be eeprom chip is bad? I would try to swap it if I can.
Also, if you go to checkit or similar, do you see it detecting VGA bios? Does it print VGA bios id information on boot?
It does print ati bios on boot vers v3m-1.0. just upgraded to dos 6.22 and interestingly during setup it seemed to identify hercules. with 6.22, no change and still same error. am using phoenix bios if this may matter set to vga. will run checkit in a moment. can reflash the ati bios if you think this may help, ill look for the file, or if you know where best to find it would be appreciated. thanks for the help..... hope to get it working!
the 5170 motherboard switch display switch is toward the front of the computer which should be correct. i can try different and original 5170 bios if you think may make a difference but i don't think it would.
is the eeprom chip different than the bios? what do I need to do to swap? do i program it with anything? also have not had luck locating the v3m-1.0 bios. did find a v3m-1.0/70 ...
Just for a sanity check: is the color/mono switch on the 5170's motherboard set for mono or color? The ATI Wonder manual says:
When installing the VGAWONDER in the IBM PC/AT it is necessary to set the video display switch (Color/Mono switch) on the AT motherboard to Color and run the IBM Advanced Diagnostics Program which will automatically configure the System for an EGA (Enhanced Graphics Adapter) Card, which is the category for the VGA WONDER.
It's set for color but I'm using a different bios. I will try the original bios and use the advanced diagnostics program.
eeprom is different, it's just a rewritable memory for a few dozen bytes. It's not the 27c256 type ROM chips. Don't change bios, it won't do any good.
Did you try it on other boards? May be something a bit more recent, like 386 or 486?
Does 5170 board have 6MHz or 8MHz CPU? At 6MHz a lot of ISA cards seem to glitch, at least for me.
Did you run the VSETUP tool from the ATI diskette ? VSETUP is used to set the default video mode or default monitor type.
Checkit says cpu is 8.01 mhz. I don't think I have another eeprom chip but I will look. would it do any good to erase it and reinsert? Unfortunately don't have a 386/486 to test... could test it in an XT? I think i read it would work in 8 bit but maybe I'm misremembering.
Mikey99, I have been trying vinstall. Ill look around for vsetup, or if you can point me in the right direction.. great. thanks
The VGA Wonder 16 is an amazing card, supports many different monitors MDA/CGA/EGA/VGA.
The card even works in an 8-bit slot. The designers of this card did a great job providing support for
users with older monitors MDA/CGA/EGA, and also supporting VGA. I still have the VGA Wonder
I bought new in 1988 ! Here are scans of the box, the table shows all the various monitors etc that
are supported.
http://www.vintage-computer.com/vcfo...1&d=1235105179
http://www.vintage-computer.com/vcfo...2&d=1235105588
http://www.vintage-computer.com/vcfo...3&d=1235106272
Oh! just saw the scans of the box. perfect. just got it working and am still testing it out. thanks again!
So your VGA card works normal now? Congratulation! Out of all ISA VGA cards, I get the best picture with ATI VGA Wonder cards.
Great card in its day but it was pricey - $500 to $700. I couldn't afford it back then.
