Shadow Lord
Okay, I had forgotten how much fun SCSI can be!
I am trying to setup an Adaptec 1742A SCSI-2 controller. The controller is installed, the BIOS is activated and I get the BIOS version info displayed. I have also terminated the adapter and the jumper is set for term power. The adapter ahas the std. SCSI ID of 7. I tried installing one SCSI-2 device (Seagate HDD) w/ SCSI ID 0. Since the HDD is the only other device on the chain I have it terminated as well. When I turn the system on however, the controller does not see any devices on the SCSI bus on any ID. I've tried switching out the cable and also using a SCSI Tape Drive (also terminated) to see if the HDD is the culprit and the result is the same. I've tried most combination of options in the SCSI cards config w/ no luck. According to the manual the card does a self diagnostic at startup and based on what I see the card is passing itself w/ flying colors. Any ideas or advice? Could the controller be bad even if it is booting, posting the BIOS, able to be configed, and passing its own self dx? I think it is something real simple that I am missing...
