Also grab the TESTFDC utility (from the same place) and start with that. Let's see what it says your drive can do.
OK, I ran FDCTEST with the parms TESTFDC A: 1.44
Got back:
TESTFDC 1.16 - Copyright 2007 Dave Dunfield - All Rights Reserved.
BIOS reports drive A: as Unknown
Testing as 1.44 HD, 80-track
250 Single-Density: Format Write Verify OK
250 Double-Density: Format Write Verify OK
250 Double/128byte: Format Write Verify OK
500 Single-Density: Format Write Verify !error (0) NoAdrMark
500 Double-Density: Format Write Verify OK
500 Double/128byte: Format Write Verify OK
Report on FDC capabilities, issued 1/01/1980 1:36:42:
Single-Density at 250 kbps...............................Passed
Single-Density at 300 kbps...............................Not tested
Single-Density at 500 kbps...............................Failed
Double-Density at 250 kbps..............................Passed
Double-Density at 300 kbps..............................Not tested
Double-Density at 500 kbps..............................Passed
Double-Density at 250 kbps / 128 byte sectors....Passed
Double-Density at 300 kbps / 128 byte sectors....Not tested
Double-Density at 500 kbps / 128 byte sectors....Passed
Thoughts?
Regards,
Mike
