Well, letting the pin "float" is lousy engineering practice and it might be susceptible to stray noise. But nothing really awful will happen under normal circumstances.
You needn't solder the stuff. For example, I will sometimes use wire wrap (AWG 30) wire wrapped around a a couple of pins.
Ah, that's better. I'll wire the two pins - just wanted to know if leaving it untied while I get the wire would cause any harm. I'll fix that today.
I did try the merged BIOS route and got pretty far until I tried to flash the XT-IDE BIOS as the final step. James Pearce gave me a handy ROMDUMP utility to easily gra b a copy the HD floppy disk controler's BIOS and write it to a .bin file which I trimmed with my hex editor down to a 4K chunk then merged with IDE_XT.BIN from the xtide-r566 zip resulting in a new BIOS bin file (NEWROM.BIN). When I went to flash the XT-IDE's BIOS (e.g. FLASH NEWROM.BIN C800) The erase operation appeared to be progressing for a few minutes then I got the following erase timeout failure:
A:\>flash newrom.bin C800
Calibrating delay loops... calibration factor is 13
Opening ROM image... OK
Unable to determine flash chip type. Attempting JDEC programming.
Reading 8464 bytes read OK.
Erasing ................................... **TIMEOUT**
Expected FFh but found 0055h Erase operation FAILED
If BIOS images currently in use have been updated, it is HIGHLY
recommended that the computer is no restarted.
Press any key to return to DOS, or CTRL-ALT-DEL to restart.
That looks like maybe the 8464 is not the full ROM memory range? These are lo-tech XT-IDE 8-bit cards I got off of eBay; I didn't built them myself, so I don't know if the problem is maybe that its a different ROM chip than what James supplies or some other cause. The ROM chip on the boards I have is an SST 27SF010 where Lo-Tech supplies an SST SST39SF010A. Maybe all I need to do if I want to flash the other XT-IDE card I have is to get a new BIOS chip directly from James?
Regards,
Mike
