I do in fact. I have already purchased and assembled mine - next release of the document for details and photographs... But I will upload a couple of photographs now to my google drive for you so you can see the result.
I bought the following parts from Pololu:
4 off 1802 - wires with pre-crimped terminals. These are multicoloured (50 pieces each of 10 colours per pack). You may decide you want all the same colour or whatever...
1 off 1844 - wires with pre-crimped terminals. These are also for the temporary jumper leads (see item 1900 below).
4 off 1037 - 2x20 pin female headers.
4 off 1025 - 2x5 pin female headers.
2 off 1917 - 2x10 pin housing (5 pack).
2 off 1992 - 2x20 pin housing (5 pack).
4 off 2748 - 2x20 pin female header.
4 off 1035 - female header set for Arduino shields.
1 off 1900 - 1x1 pin connector housing (25 pack). I think I was going to use these for temporary jumper leads - but they may be the wrong size for the wire-wrap spills. EDIT: Just tested them again (to make sure) and they are too small to fit on the IC socket wire-wrap spills.
There are two (2) types of female headers - those that have leads that can be wire-wrapped (well, sort of). These are for the LD12. And the other type (solder) that are for the front panel.
I found a had to use a bit of sandpaper on the female headers to get them to sit end-to-end. Their definition of stackable and mine are not the same thing!
EDIT: IMG_0441 is the top view (the male headers are just to keep all the individual female headers in line whilst I solder them to the LD12 PCB).
EDIT: IMG_0447 is the bottom view (with a temporary 5V supply connected to test out my DEBUG LED display).
In this post is weeks of research and experimentation
! The wires with pre-crimped terminals and the housings interconnect the LD12 to the LD12FP. They just plug in. I decided to purchase pre-crimped terminals to give it a more professional look and I just couldn't face the idea of assembling all of those cables...
Working on the IC VCC and GND interconnection table this weekend. And then I shall start working on the interconnection tables for the MA, PC, IR, MB, AC, MUX and ALU registers and busses next. Each of 12 bits...
