Nama
I have been restoring a 386, and have been experiencing a weird problem in that when an IDE device is attached (e.g. IDE drive, or CF card in a CF to IDE adaptor) I am unable to boot from a floppy drive. On boot-up the machine posts and the floppy drive is accessed and it seems to start to load, but then the machine just seems to hang (no onscreen prompts about FDD failure or anything).
I am however able to access the floppy drive after booting from the IDE device with no noticeable issues. If I remove power from the IDE device, only then can I then boot from the floppy.
I have tried deactivating the IDE device in the BIOS (but still keeping power connected to the IDE device), changing the boot order, changing floppy drives inits (both 3.5 and 5.25)... but the only thing that works is physically removing power from the IDE device, then I am able to boot via floppy.
Wondering if anyone has any ideas what could cause this?
Cheers
Cheers
