Wreck
Hello Forum
I found the forum (and the incredible wealth of information available) whilst struggling to "fix" my three CBM3032s sitting in my basement.
I am an electronics "newbie" , and have little knowledge of the subject (I know how to use a multimeter, got a logic probe and an old Oscilloscope at hand).
As I mentioned before, I have two non working CBM3032s on my bench; one shows the garbage screen, the other has probably worse issues.
I am focussing on the garbage screen machine; I measured voltage on the main regulators, checked resistors and confirmed that all components get current.
The machine still wont boot up, I suspect somehow the cpu is stuck at some point (is there somewhere reference about the individual "steps" the 6502 performs chronologically?).
I used a ROM/RAM board, but there is no difference. Pressing the reset button on the board just changes some of the random chars into small font.
If I "wiggle" the board, there are sometimes vertical lines appearing, striking through the characters. I will eventually try to post a picture, as it is a bit difficult to explain.
I was thinking to replace the Elkos to rule out some gremlins - but when looking at replacement elkos, I am surprised to see their size is almost half of the old ones. I am a bit unsure about that.
I will try to measure all pins on the 6502 and check their state with the probe, maybe this could hint to something.
I am very grateful and happy for any tips
Thanks
Joe
Thanks
Joe
