daver2
10k Member
They look good.
Let me get back to you shortly with the next step...
Maybe the ram extension board is the problem ?Excellent.
Did you accidentally measure J8 pin 1 instead of J10 pin 1?
-6V seems a bit low to me.
If so, can you remeasure at the correct point please.
Can you also measure the DC voltage on J8 pin 2 please. This was going to be my next voltage measurement anyhow.
I was just going to ask you to measure the voltage across the "big capacitor" and to verify that it is approximately 10V DC!And i just spot that theres now 10v at the bic capacitor instead of 0.1v now
This is possible - let's just take this one step at a time...Maybe the ram extension board is the problem ?
Cr6 is 8v one side 5v the otherI was just going to ask you to measure the voltage across the "big capacitor" and to verify that it is approximately 10V DC!
So far so good!
Your problem was possibly some oxide build up on connector J8 that has now gone since you have removed it and reconnected it.
Next, set your multimeter to read DC volts.
Connect the black (negative) lead of your multimeter to the black (negative) lead of the external big capacitor.
Measure the DC voltage at the following points:
Diode CR6 - measure the voltage on both wires of the diode with the red (positive) lead of your multimeter.
Diode CR7 - measure the voltage on both wires of the diode with the red (positive) lead of your multimeter.
Diode CR5 - measure the voltage on both wires of the diode with the red (positive) lead of your multimeter.
Diode CR1 - measure the voltage on both wires of the diode with the red (positive) lead of your multimeter.
Note that all of the voltages should read positive - with the exception of those for CR1 that should be negative. If you are using an analogue multimeter, you may have to swap the multimeter leads over again.
These readings measure what DC voltage is going into each voltage regulator (and should align with what you have already measured) and what is coming out of each voltage regulator. We are now checking that the voltage regulators are working correctly.
I don't feel comfortable to do it i don't have a chip extractor and i just retried the cbm with the extension board still the same thing because as i know the cbm have a boot chime and also the processor seems very stuck in place and maybe i can buy a new one to place on the motherboard i juqt found one on ebay for 10 eurosThey all look good as well. So far so good.
I assume the CR1 voltages are really negative (unless you swapped the probes around of course)...
My next question is regarding the memory expansion board.
I would recommend first trying to get the PET running as simply as possible. This should involve just transplanting the 6502 CPU from the memory expansion board to the PET logic board - observing anti-static precautions and making sure you insert the 6502 chip the correct way round into the socket.
Before you do this - is this something you feel comfortable about doing (bearing in mind if you insert the CPU in the wrong way around you could do some damage to it).
I tried the cbm with the expansion board and it's still not workingThat's why I asked.
So, if I understand you correctly, did you put the memory expansion board back into the PET and give it a try or not? If you did install the memory expansion board, did you measure the DC voltage across the large external capacitor to see whether it was correct this time or not?
If you want to buy a spare 6502 CPU that seems a reasonable price. Although the usual rules apply for buying from eBay...
You may also like to consider a ROM/RAM replacement board (e.g. https://www.hackster.io/news/the-ro...placement-for-your-commodore-pet-50d9077bdfcc and https://bitfixer.com/product/romulator/). I think both suppliers make a ready-built unit so ignore the 'kit' and ask the question.
Both of these cards permit you to replace the ROM and RAM of the PET with known good parts on the replacement board. You can also change the version of BASIC to the latest version. Both of these cards have in-built test tools (such as a NOP generator and my PETTESTER firmware) to help diagnose problems further. Can I suggest that you read up on these and consider them for later if we need them?
I can purchase a 'reasonable' multimeter for less than 10 GBP each in the UK.
