Yes Dave, stable!But you are not telling me whether they are stable on the oscilloscope trace or not...
You must tell me what I am asking!
Hi Nivag! Yes i have only your diagnostic board without CPU!Can you confirm in the E test above that you have removed the CPU?
I will do these test tomorrow morning...have a good evening guys! Thanks so much for your help!Ah, if you slowly advance the video you have an almost page of E characters but with a band of none E characters moving across the page.
Can you scope the pins of F9 please. The data input and output pins should be stable and correspond to the logic levels of the 'E' character that we have configured on the video RAM outputs.
Pin 11 should have the video latch clock and pin 1 should be LOW.
Why do you wave the white flag when we have a new lead to follow?
Yes sure, the previous measurements are made when display is incorrect....in this last case i measured also with correct display but i have always same noise!I would stop doing that!
I suspect your oscilloscope is loading that pin up too much. Not sure why just yet. Let me think about where to measure that by looking at the schematics. If I ask you to measure this (or a similar pin) again, just 'dab' the oscilloscope probe on for a very short period of time. Too long could damage the monitor.
However, one thing I did notice from your screen, is a perfect load of 'E' characters. You have waited for the logic to warm up BEFORE taking all of the above measurements haven't you? If not, all of the previous measurements are invalid. We are trying to measure things when the display is incorrect...
