FelisSapien
Hi All,
I'm back with a query on my PET, this time with ROMs... If I run a RAM/ROM test I found somewhere an error is reported. I'm not sure what to make of the results:
I've dumped the ROM images to file and produced MD5 checksums to compare against known good files:
All checks out well. So now I'm not sure what to make of the situation. Advice please.
The only odd behaviour I'm experiencing is (again) with the SD2PET. When first turning on the PET I see what seems to be random behaviour with the CATALOG/DIRECTORY/LOAD"$",8 commands. The first command I try will fail, the second or third will usually work. It doesn't seem to matter which combination of commands I use. Typing this out now I realise this could be a remaining gremlin in the area of IEEE-488. Or maybe it's a quirk of the device? Once a command to the disk is accepted then I don't have further problems.
Cheers,
Carl
Cheers,
Carl
