| VCF Latam | Apr 24 - 26, 2026, | Bahía Blanca, Argentina |
| VCF Pac. NW | May 02 - 03, 2026, | Tukwila, WA |
| VCF Southwest | May 29 - 31, 2026, | Westin Dallas Fort Worth Airport |
| VCF SoCal | See you in 2027, | Southern CA |
| VCF East | Apr TBD, 2027, | InfoAge, Wall, NJ |
Not necessarily. Sometimes it can cause black screen, other times it will just sound terrible if it's bad.on the commodore 64 if the sid fails, it causes a black screen. If you remove the sid, the screen reappears!
Hi, not again...Sid i solded on board...Not necessarily. Sometimes it can cause black screen, other times it will just sound terrible if it's bad.
Curious though, has removing non essential chips been considered? SID is on address lines 0-4, and data lines 0-7. If it is faulty it might screw with those signals. (I haven't looked at the 710 schematics and basing that on the c64)
I thought I would find a new 6509 cpu in my Easter egg but unfortunately it wasn't there....maybe can I try with a 138 ic piggyback ?Forget it.
I don't think it is.
The only way you could do this is to remove the CPU, plug it into a breadboard and write a simple program to store into EPROM (also on the breadboard) that will do something useful (like flash an LED).
However, you will also have to produce the RESET and CLOCK signals for the CPU.
You will also have to wire all of this up.
I don't think your skillset covers doing something like this - you are only going to kill the CPU (if it isn't already dead).
Best leave this for someone else. Please...
ALT/CHOP is IN now....
There isn't any manual online...
Need i buy a new digital scope![]()
ALT/CHOP IN means Chop mode is active, right? Could it be that the oscilloscope has a hard time to keep up switching between CH1 and CH2 at the rather fast time base settings? The posted manual states that the Chop mode is more suitable for slower sweep speeds. I do however not have any experience with analogue scopes, so this is purely speculation from my side.And TRIG.ALT button. IN or OUT?
Can you post the manual then (if you have a scan of it)?
I am interested in the operation of the MODE switch.
>>> Time to move trigger probe on Gnd, isn't?
Why, this just displays a horizontal line... To what end?
You cannot handle an analogue oscilloscope at the moment. Until you are able to do, buying a digital oscilloscope will confuse you even more.
If you can't drive a Fiat car correctly, there is no point in buying a Ferrari...
