YES because on ub13 pin7 i have pulsing signal if i touch pin with probe..i don't have continuity between ub13 pin7 and uc9 pin 5UB13 is sitting in its socket OK with pin 7 actually in the socket isn't it (rather than being curled up under the IC). Yes, I have had a fault like this before!
Just checked, it's the same finally !!!If you go back to post #291 and look at the documentation I wrote for the PETTESTER firmware (on page 3 of 16) you will observe what a 'good' 80 column display should look like. You can print this page out and check your PET screen yourself.
Well!Excellent!
Right, so I need to give you some continuity checks to do with the power off using your multimeter.
First of all print out this schematic http://www.zimmers.net/anonftp/pub/cbm/schematics/computers/pet/8032/8032029-09.gif.
Next, look at the signals named OSD0, OSD1, ..., OSD7.
They go from the RAM (UC6 and UC7) to the 8-bit latch (UB8) and to the buffers (UB6 and UB7).
Work from OSD0 through to OSD7.
With one probe of your multimeter on OSD0 on the associated RAM chip (in this case UC6 pin 14) test for continuity to all of the other locations it is supposed to go to with the other probe of your multimeter (i.e. UB8 pin 3, UB6 pin 2 and UB6 pin 3).
Move on to the next OSDx signal and repeat for them all.
After that, repeat the same process with the signals ESDx found on schematic http://www.zimmers.net/anonftp/pub/cbm/schematics/computers/pet/8032/8032029-08.gif.
We have to do the same with another schematic - but I will give you that homework after you have done this !
Obviously, check with your multimeter probes on the pins of each IC to ensure full continuity.
What we are ensuring is that pins that should be wired together actually are!
Good Sunday Dave,Excellent!
You now need to repeat the continuity tests with the signals called BD0 to BD7. For this you will need a new schematic (http://www.zimmers.net/anonftp/pub/cbm/schematics/computers/pet/8032/8032029-01.gif) in addition to the two schematics you already have.
Let’s start with BD0 shall we?
Put one of your multimeter probes on UB10 pin 17, and then chase this signal around the other places it goes:
UB10 pin 18.
Then over to schematics 8 and 9 (that you already have) with UB4 pins 17 and 18 and UB6 pins 17 and 18.
Repeat for signals BD1 through BD7.
