NobodyIsHere
- Joined
- Dec 20, 2006
- Messages
- 2,412
Hi,
Does anyone know the definitive way to safely clean vintage circuit boards of old dust and cigarette smoke film? I would like to clean them with the minimum risk of damage to the legacy circuits possible.
I have read many articles on the web, usenet, and even here but the advice is conflicting with some advocating soap and water, others using compressed air, or other techniques. The dangers range from metal corrosion to ESD and a whole host of confusing subjects.
Maybe there is no simple answer but I would like to clean some boards up. In particular, I have an older machine which just plain smells bad due to its unique history however, I am very hesitant to use vacuum cleaners or blowing compressed air due to the potential for ESD unless absolutely necessary.
Apparently you can use soap and water to clean circuit boards and it might work or it might not depending on who you ask. However, I'd rather leave them dirty and smelly rather than risk ruining an almost irreplaceable vintage circuit board.
Thanks in advance.
Andrew Lynch
Thanks in advance.
Andrew Lynch
