daver2
10k Member
There is a way of testing the pins with a multimeter set to read resistance. Set the lowest range possible on your multimeter.
Obviously, do this test with the PET power off...
Pin 1 of H4 should be connected to pin 1 of H7.
Pin 2 of H4 should be connected to pin 2 of H7.
Likewise for all of the remaining pins of the ROMs in sockets H4 and H7.
This is also true for EVERY pin of EVERY ROM - except pin 3. For example, pin 1 of H1, H2, H3, ..., H7 should all be connected together.
Try not to apply too much pressure to the multimeter probes. We are looking for a mechanical (IC socket) defect, so pressing too hard on the pins may cause a connection to be made when it was faulty. This defeats the object of the test!
If you find any issues, post them and I will have a look.
Do you have a logic probe or oscilloscope? There are better ways of testing this using the EAzy link of the ROMulan if you do!
