I've pretty much wrapped up setting up and configuring the maxed-out DeskPro 286. Here is my final hardware and software setup:
Hardware:
Compaq DeskPro 286 ver 2 @ 12 MHz
80287
4.1 MB Extended RAM (2.1 MB on motherboard + 2 MB Intel AboveBoard)
16 bit VGA (bog standard, nothing exciting)
COM1, COM2, LPT1, LPT2
1.44 MB floppy drive A:
SN2000 (NE2000 compatible) Ethernet card with Universal BIOS 2.00 beta3 in boot ROM socket
Compaq Enhanced keyboard
Serial port mouse on COM1
Iomega ZIP 100 on LPT1
System Software:
Compaq MS-DOS 5.0 (620624 bytes avail)
MS network client 3.0 - TCP/IP stack connecting to Samba server (399360 bytes avail with 1 drive mapped)
Windows 3.1 in Standard mode (3,390 KB free, 86% Resources free)
Application Software:
MS Office 4.2
MicroGrafx Designer 3.1
Windows Entertainment Pack
Development Software:
MS MASM 5.1
MS C 5.1
Turbo Pascal 7.0
Borland C 2.0
Borland C++ 3.1 (sort of - 16 bit Windows Apps only)
To reiterate, I hadn't used a 286 machine since Reagan was in office (and just barely his second term). Never impressed me much, but I learned a lot from this exercise.
First off, as a pure DOS machine, it wasn't a huge leap from the DeskPro 8086, especially with a NEC V30 CPU. Coming from a 4.77 MHz 8088, however, it was a pretty decent upgrade. Hard drive I/O performance was improved with the 16 bit ISA bus even with the same drive type. I moved a modern-ish 20 GB Maxtor IDE drive from the DeskPro 8086 with XT-IDE to the DeskPro 286 using the same version of the Universal BIOS but using the Compaq AT hard/floppy drive controller. Clearly faster on the 286. But DOS didn't provide much improvement over the 8086 as access to the extended memory was near impossible. Only with the Compaq version of HIMEM.EXE to enable the HMA so DOS could be loaded high was there any indication of the additional memory. Of course, the AboveBoard would need to be reconfigured as expanded memory for DOS applications to take advantage. Still no real improvement over the 8086.
The only DOS specific programs I have are development tools. Even by 1989, the 80286 was being dropped in favor of the 80386 and 32-bit DOS extenders. The last real-mode version of Microsoft C was 5.1, and Borland's C++ was 2.0. Real-mode assemblers and Turbo Pascal (even ver. 7) hung around a little while later.
Other 80286 OSes I didn't try were OS/2 and Xenix. OS/2 on a 286 was pretty pointless, hardly any 16 bit programs to run. Xenix is somewhat interesting, and would have been a solid choice if it ran the application you needed. Since I already run Xenix 86 on a DeskPro 8086, I didn't see any need to investigate this route.
The saving grace for the 80286 was Windows 3.0/3.1. Really the only way to take advantage of the extended memory and still run a large library of applications. MS Office 4.2 runs, but using the desktop publishing features of Word will test your patience. Excel seems to run pretty well, especially with a 80287. Micrografx Designer ran up to version 3.1 (later versions wanted Enhanced mode) but it isn't something you really want to run on a 286 and VGA @ 640x480. Interestingly, Borland C++ 3.1 installed and the Windows IDE ran and compiled programs. The DOS compiler was 32 bit extended though, and I had to revert to version 2.0 for command line operation. Really, anything released after 1992 seemed to require Enhanced mode. Whether they needed 32 bit instructions or extended memory access I don't know, but they didn't care to support the 80286.
So, this whole sheltering at home time gave me the opportunity to see how far I could push a maxed-out 80286 machine. It was definitely a viable platform for light office work well into the '90s. Almost a 10 year life span (if you include the original IBM AT) during a time of rapid advancements. Not bad, but I wouldn't have traded my DeskPro 386 for one.
