NTICompass
I have a Compaq Portable III (286), just like in this thread, and it needs a new CMOS battery. My motherboard does not have a DS1287 chip, it just has the LTC-7P-MP-F-S2 battery.
The LTC-7P-MP-F-S2 battery is no longer available, and I don't know what a good replacement is. Here is a picture of it (not mine, but the same): https://mobile.twitter.com/Foone/status/1416175186055864321
It's a 3.4V battery, with 4 legs. Why does it have 4 legs? Can I just replace it with a CR2032 or something? I assume I can use 3.6V or even 3V without issue... right? Which of the 2 pins on the board would I need to use? Is there another viable replacement?
EDIT: Found another thread with a possible solution: https://www.vcfed.org/forum/forum/ge...120#post887120 Looks like you can just throw on a 3.6V battery! Also it shows where to attach the wires!
EDIT 2: Do I need a 3.4V or 3.6V battery? Or can I use a "normal" 3V CR2032? What would be the easiest battery holder to add to this system?
