Compaq SLT 386s/20 power supply pinout
I'm not clear on the question but I'll throw this out there, maybe it will help others.
From my research you could buy a 6 pin dual row connecter from Adafruit and it will fit in the hole side of the Compaq. You'll still need a casing around it for a clean look and to prevent a user from plugging it in upside-down but it does make for a great start. I had started working on a 3D end to fit another less pretty solution. I'll have to look for it.
I understand that you can use dupont connectors, I already have the part. What I want to know is if the original adapter had anything to interface with the two ground pins on the side. See picture below.
Oh wow. I never realized those were grounds, actually never realized those existed. I have a PS I can see if there are any contacts on the plug for those.
Thanks. I am trying to make as accurate a replica as a can, and I am rebuilding the battery pack so I might hit you up for more info later if you have an actual wall adapter (not the car adapter). But no matter which adapter you have, I am curious about how that interact with those supposed grounds. I almost wonder if they are just for retention and they are only coincidentally grounded (as others have reported, anyway).
I have the AC power adapter, not the Car DC one.
Attached is the plug I had started working on. It wasn't designed for the Adafruit connector as I hadn't made that discovery yet. What it could do was take in 6 stranded wire carefully pushed through the back of the plug, one or two strands a time and extended past the other end, then bunched together carefully and pushed back into the receptacle. It was a very tight fit by design. A little super glue would keep them in place. I didn't like the look or the quality of the wires and they weren't available in super long lengths as I'd like. In a pinch though, it's a good idea at least to get power to the Compaq. I didn't print it for looks yet, this ws more of a fitting. Once satisfied I'd increase the resolution and make it pretty, also need to cap the end where the wires come out to the power supply.
Can you please do continuity testing on the 18v charge and tell me what pins have continuity? I am wanting to make sure I get the battery charging circuit connected correctly because I will be rebuilding my battery pack as well.
Sure. I broke my leg a couple of weeks ago but luckily the power supply and voltmeter are accessible by crutch.
Also, if you get the battery case cracked open, please share any tips. I've tried multiple times and never even get a light crack. Wondering if the lid is completely glued to the bottom. I have two or three that I would like rebuilt for my 3 SLTs.
I saw on a video that it takes a heat gun and a long time to crack into one.
Measuring the power out from the cable is harder than expected. I can only assume the output voltage depends on what the battery charging sensors are reading for how low the battery state is in as my voltages read much smaller than expected. My guess is that the power output depends on the voltage read in on the battery sensor lines. I get 6.26 volts out of line 4 in the picture when the power supply is not plugged into the computer. I know this power supply is good as it charges an SLT that has a working battery.
Also, the metal around the plug is producing voltage. I measured +2.5 compared to ground. I do feel voltage when I touch it which is probably not good.
Have you read this post?
(1) Compaq SLT/386 or SLT/286 Power Supply Pinout | Vintage Computer Federation Forums (vcfed.org)
Sorry I could not be more helpful.
Yes I have. I know where the voltages come in, what I am wondering is if there are continuity between any of the pins. Maybe some of them form a bridge to charge the batteries?
Hello everyone,
I’ve also restored a Compaq SLT/386s/20 and got it working again—thanks in part to the information shared here in the forum. So thank you for that!
I’m currently in the process of rebuilding the battery, this time using LiPos with a BMS.
I’ve discovered how to activate the charging LED on the power supply: if you apply a high-impedance voltage between 0.5–0.75V to the pin next to the + terminal of the battery, the red charging LED on the power adapter lights up. However, the power supply makes a different noise compared to when it’s just plugged in and running the laptop, or charging the battery.
Everything works—the new battery charges—but I’d really like to understand what exactly is happening inside the power supply when the red LED is triggered.
I believe I once found a link to a schematic for the SLT power supply, but I can’t find it anymore!
Does anyone have a schematic for the SLT power supply?
Georg
P.S.: If I’ve understood everything correctly, I’d be happy to share my findings here.
Hi @fft, welcome!
I have since passed on my machine since I didn't get it to work, but I'm sure others might appreciate you sharing your findings. Unfortunately I don't recall ever seeing schematics for the PSU, so I'm afraid I can't help.
Cheers
mikerofone
Also, I believe there are different internals in the SLT power supplies, they are not all the same. I believe this is true even on ones with the same part numbers. There is one or two YouTube videos on repairing one of the models.
Have you happened to find a video that describes how the PSU works?
What up gangstas
I have torn apart the OG battery in my SLT 386 and thought you guys would care to see.
Replaced it with 4x 18650s in series and used the original charging circuitry
Its brutally simple, looks to be just a transistor and a bimetallic heat fuse
This forum has helped me a lot, figured I'd give some back.
It looks to be basically 8 C-cell nickel cadmium batteries, nothing special at all
New power pack works. Have not attempted to charge it yet though.
I used a soldering iron and sliced open the top instead of melting the glue with a hair dryer. Plan on 3d scanning the battery cell and maybe I'll manufacture a limited run of these. If I can sell more than a couple might be worth my time making them.
