djyuran
Hello!
I got 8088 laptop Panasonic Business Partner 150 (https://space-nerd.com/en/1990/05/2...150b-no-frills-laptop-features-bright-screen/).
Person I bought it from replaced FDD to 1.44Mb but controller supports only 720Kb 3.5".
I have a lot of 1.44Mb floppy disks so I converted several disks to 720Kb with a patch on a small window and formatted them to 720Kb.
They work well on my other retro PCs (with 1.44Mb FDD) but they work weird with this laptop.
FAT is readable but when I try to copy a file it shows me a error with Abort, Retry, Fail.
Retry sometimes helps. So it works but very unstable and mostly unusable for me.
What could be a reason?
I found an interesting explanation here https://www.instructables.com/Convert-a-144mb-floppy-to-720k/
"I have experienced that converting an HD (1.44MB) to a DD (720K PC/800K Mac) disk this way it may cause problems when the disk is used and already formatted in the HD format.
The original HD layout will not be properly erased, instead only the DD format will be recorded over the HD format causing an unusable disk."
Does it sound correct?
