So leave 47 removed, and just insert the temp wiring on 55, correct?2. Remove ICs 47 and 55 from the Dazzler. Insert some temporary wires into the following pins of IC socket IC55 and connect them to 0V: pins 11, 6, 3 and 14.
Yep it does, it doubles the number of vertical lines.Now can you change D5=1.
This should double the resolution.
Can you set D7 to D0 as follows (using my test program):
0011 1001
In theory, the display should not change from what it is now.
Yes adjusting the outputs through the test program, not modifying the wires.Hang on a minute, you are adjusting D7 to D0 in my test program and not the wires connected to IC47 and IC55 aren't you?
