daver2
10k Member
I think I 'may' have found a video incompatability that may make the CT-1024 not work with a 'bog standard' monitor - although I need a bit of time to think through the implications.
The original Radio Electronics construction articles can be found at http://www.swtpc.com/mholley/RadioElectronics/RE_CT_1024.htm in particualr the February edition http://www.swtpc.com/mholley/RadioElectronics/Feb1975/RE_Feb_1975_pg30.jpg identifying the video output specifications. The article states that the video output pulse is 2.25V with a 1V sync pulse. This is not what I would expect for a video signal. I am used to 1V with a 0.3V sync pulse. There also may be some issues with the number of lines (frame rate) being different to a 'standard' monitor (whatever one of those is...). Again I need some time to think about this.
The voltage levels can be fixed very simply with a small plug-in adapter board on the video output of the CT-1024. The number of lines issue I need to think about...
Just some thoughts in passing based upon what I have read today.
