Dauphin DTR-1 Pen\Stylus
Compgeke
Fairfield, CA, USA
After a long time I finally got them, however I didn't get the stylus' (or is it stylie) with them, nor floppies but the stylus is more important to me. Based on the screens they appear to need a pen similar to the one used on the old Wacom based Tablet PCs such as the HP tc1100 as it's a hard screen and doesn't appear to be pressure sensitive. I'm fairly certain that with the age of these a stylus wouldn't be powered by the digitizer as was the case of the HP tc1100, so I'm going to assume that the pens are battery powered.
So, based on this, where would I be able to find a battery powered stylus for these, or is it something different that I've never seen?
Thanks!
Micom 2000
Manitoba North of 50 degrees Latitude
Yes they are battery powered. I have 2 different stylus.(no I wont part with them). One is powered with an AAAA battery. (Yes 4 A's) They are fairly expensive. The other is powered by 3 watch-sized batteries. I believe the Fujitsu Stylus stylus will work with them. They turn up on EPay occasionally. IIRC there is a thread on the subject in this section.
