reenigne
You're saying ORG needs to be the offset, so if I do a far jump to FF80:0000, then ORG should be 0 right?
Right. (The far jump needs to start at address FFFF:0000 or 16 bytes before the end of the file).
Or did you mean the scenario for when it's being run under DOS debug at 100?
In that case, ORG 100h is the right value (and is probably the default, especially if outputting a .com file).
And if your far jump is to FF70:0100 then "ORG 100h" will be right for both.
