MossyRock
I've acquired a WT78, RX02 dual drive, a DECPrinter III, and its mobile cart/rack. Attached is a stock photo of a WT78 system unit.
It's all been in storage for about 20 years, I estimate. There's some corrosion and rust here and there on the peripherals and mobile cart/rack, so the storage environment was not ideal.
I powered on the WT78 with no peripherals connected and the "CPU OK" and "DC OK" LEDs illuminated, but there was nothing on the CRT, even after several minutes of warm-up. I did hear a high-voltage whine from the CRT transformer(s). I turned up the CRT intensity and it blew the 3A fuse. I replaced the fuse with one of exact specifications and it did not blow. The original fuse had probably become brittle. However, nothing ever appeared on the CRT - no cursor, no raster, even after a generous time for warm-up.
There was no smoke or sparks, no unusual smell.
I can find no archived service manuals on the WT78. The closest manual I can find is one for a VT52. The WT78 is a VT52 with an added motherboard and other parts to make it a computer.
The VT52 service manual says that a blinking cursor should appear after power on and 30 second warm-up.
Does anybody know if the WT78 behaves in the same way - should a blinking cursor appear power on and warm-up, or perhaps a BIOS message?
I'm not experienced in working with CRTs, and as such I am not going to attempt anything inside the unit. If there's trouble here, I'm going to donate it all to a local computer museum.
Thanks.
Thanks.
