maxtherabbit
Is it possible to non-destructively depin a D-sub connector? I'm referring to the type where you crimp the contacts onto the wires and shove them into holes on the back of the d-sub. Is there a way to get them back out?
The red and white ones are all over the web. I didn't much care for the construction and made my own by boring a pin-sized hole in the end of a length of brass rod, turning down the rod to match the clearance between pins and attaching a wood handle to the end. The trick is that the depth of the hole must be slightly less than the protrusion of a pin in the shell. A quick push or tap on the handle end and the pin comes right out, without being bent.
Nope--the "locking mechanism" is in the shell and is overcome by force. Eventually, it wears out, but it takes quite a few re-insertions of a pin to do that.
If you have never used one of these D-sub pin extraction tools, you might want to read through "Bob's Shop Notes: D-Sub Pin Extraction."
