That's good to know, so I could hold onto it for parts, but maybe I'll never need them. What do you all think about powering it up in this condition, safe enough or bad idea? I imagine it'd be easier to sell if I confirm it's functioning.
Would it be a good idea to disconnect the tube prior to moving this? The side of the display with the circuit board isn't entirely intact either, so if it bends the wires could be yanked tight and might crack the tube. From a video it looks like you simply pull the small board behind the cathode straight back to remove it. Then if I end up shipping it anywhere I presume it'd be good to fill the entire monitor cavity with packing material so that it's well padded and nothing can slide around. Perhaps it'd be better to fully disassemble it, though I'm going to need to know how to discharge everything before attempting that.
