The resolution of a fiche exceeds the means we're applying here. However, while not quite enough to render full quality, achieving actual 9600dpi would provide images good enough for our purposes. As you can see from 1ajs's 4800dpi example, even these could "nearly do".
ddyer - The 20MP camera method you suggest would not be sufficient for an entire fiche as it would be equivalent to only 4800dpi if it photographed one inch square. Fiches are ~6x4 inches.
The scanner employed by 1ajs made an image 11733 x 19292 [ equivalent to 226MP ] and he covered only 1/3 of the Fiche. To do the entire Fiche at the same res would need 35199 x 19292 [ approaching ~700MP], and need nearly 3GP to get to 9600dpi. Still - while there might be a slight focus issue, common with many flatbed scanners, his results are quite good - as I tried to say earlier. The choice of JPG format for the file probably degraded the image, as evidenced by the fact that it's only 5MB as a JPG, and indicates a large amount of compression loss.
Ulli, I did receive your PMs, an apologize for not responding promptly. I've been much less participatory in the forums, and this activity, for the last 6 months than I expected. I've been distracted by a health issue with a family member, which has consumed my available time. During that period, I've only posted here as a means to retain my sanity. [ and I'm losing ]
We did have a member volunteer that he had Source fiches of a version of VMS. [see previous post] I haven't had time to check with him to see if there's anything to be of assistance to you.
Unfortunately, I have no catalog of fiches in my possession and there is not yet a "collective" list either. Communicating here has been our means of addressing specific requests up to this point.
It has become clear to me that sharing images of entire fiches, such as the one posted by 1ajs, will be the best way we can progress on this effort. My activity [as much as I've had time for] has centered around mechanizing that capability, and researching software to perform the conversion to PDF. My hope is that then, interested members can share these huge images and using the software, lend their time to the conversion effort - "communally".
Another element is the construction of a web repository to contain Fiche catalogs of members, to act as a share point for unconverted Fiche images, as an exchange / archive for their PDFs, and to facilitate the management / review of same.
That's the whole project I have in mind, in a nutshell.
Good to see there's interest out there - makes me feel like we are accomplishing something doing this.
