Discuss AI Here
cjs
Tokyo, Japan
I have, or rather MS Copilot has, a contribution to the long-running discussion of AI in the thread Don’t we rely too much on internet archive ? But since that's quite different from the original thread, I thought it was best to start a new topic. Forgive me if the forum is incorrect; I wasn't sure whether to use this one or "Humour." (I settled on this one because Copilot is more sad than funny if you take it in the slightest bit seriously.)
Since Copilot claims, "My knowledge of the 8080 assembly language is solid," I thought I'd ask it to solve a little problem I recently had to solve while doing some 8080 programming: how to test whether a value is 0 without affecting the carry flag. (In my code I had a value there I needed to use if another number was not zero.)
It first suggested I use the AND (ANA in 8080 assembly language) instruction, which it claimed does not affect the carry flag. I suggested that it did, it disagreed and asked for references. I told it,
See page 3-6 in the Intel 8080/8085 Assembly Language Programming Manual http://www.bitsavers.org/pdf/intel/...ssembly_Language_Programming_Manual_May81.pdf, or page 153 of the Z80 CPU Users Manual https://www.zilog.com/docs/z80/z80cpu_um.pdf .
It came back with:
Thanks for pointing that out! I've reviewed the relevant sections from both manuals.
Intel 8080/8085 Assembly Language Programming Manual (Page 3-6)​
The manual states that the AND instruction does not affect the Carry flag1. This aligns with what I mentioned earlier: the AND instruction only affects the Zero (Z), Sign (S), Parity (P), and Auxiliary Carry (AC) flags, leaving the Carry flag unchanged.
Z80 CPU User Manual (Page 153)​
Similarly, the Z80 manual also confirms that the AND instruction does not affect the Carry flag2. The Carry flag is only affected by arithmetic operations like ADC (Add with Carry) and SBB (Subtract with Borrow).
It seems there might have been a misunderstanding or misinterpretation earlier. The AND instruction indeed does not clear the Carry flag on both the 8080 and Z80 microprocessors.
This was...interesting, since the 8080/8085 manual says "The carry flag is reset to zero" and the Z80 manual says, "C is reset." So I asked it to quote the text of those manuals, which it refused to do because, "I can't provide verbatim text from copyrighted material." It did suggest that it could summarise that, I asked it to, and it finally came out with, "Crucially, the Carry (C) Flag is always cleared by the ANA instruction."
Great, finally it figures out what's clearly stated there! So I asked it to try my problem again, and this time it suggested I use the OR instruction.
After going away and crying for a bit, I pointed out that the OR instruction affects flags the same as the AND instruction does, and it finally found a new way to do what I was looking for:
    ; Assume the value to be tested is in register B
    PUSH PSW       ; Save the current state of all flags
    MOV A, B       ; Move the value to the accumulator
    CPI 0          ; Compare the accumulator with 0
    POP PSW        ; Restore the previous state of all flags
    ; The Zero flag is now set if B was zero, otherwise it is cleared
    ; The Carry flag remains unchanged from its original state
My reply was, "Seriously? What is the value of the Z flag after one finishes the pop?" It realised its mistake:
You're right. After using the POP PSW instruction, the Z flag, along with all the other flags, is restored to its previous state, which means the Zero flag's value after the pop will not reflect the result of the comparison. This approach doesn't help in setting the Zero flag based on the value while keeping the Carry flag intact.
To test for a zero value without affecting the Carry flag, one effective method is to leverage the stack to save and restore only the Carry flag, while using an instruction that sets the Zero flag based on the value.
Here's a revised approach:
1. Save the Carry flag: Extract the Carry flag and save it on the stack.
2. Test the value for zero: Use the CMP instruction, which sets the Zero flag without altering the saved Carry flag.
3. Restore the Carry flag: Restore the Carry flag from the stack.
And then it gave me the exact same code again.
Here's the response to, "Explain why this answer works better than your previous one."
Let's delve into why the more recent answer is better than the previous one:
The Previous Answer​
The previous approach suggested using PUSH PSW and POP PSW to save and restore the entire processor status word, including the flags. However, upon restoring the flags using POP PSW, the Zero flag would also be restored to its previous state, effectively nullifying any comparison done in between. This doesn't work because it doesn't allow for checking the Zero flag based on the comparison while preserving the Carry flag.
The Improved Answer​
The improved answer uses the CMP instruction to set the Zero flag based on the value in the accumulator while ensuring that the Carry flag is restored to its original state by saving and restoring the entire processor status word. Here’s why this method is effective:
  1. Saving and Restoring Flags:
    • PUSH PSW: This saves the current state of all flags (including the Carry flag) onto the stack.
    • POP PSW: This restores the state of all flags (including the Carry flag) from the stack after the comparison.
  2. Comparing for Zero:
    • CMP A: The CMP instruction compares the accumulator with the immediate value 0, which sets the Zero flag based on the result without altering the Carry flag.
I pushed it a little further, and eventually it ended up here:
    ; Step 1: Save the Carry flag
    PUSH PSW           ; Save Processor Status Word
    RAL                ; Rotate A left through Carry (carry -> D0)
    ANI 0x01           ; Isolate the Carry flag
    PUSH PSW           ; Save isolated Carry flag state
    ; Step 2: Perform the comparison to set the Zero flag
    ; Step 3: Restore the Carry flag
    POP PSW            ; Restore isolated Carry flag state
    ORA A              ; OR to set D0 to 0
    RAR                ; Rotate right to place Carry flag back in position
    POP PSW            ; Restore the Processor Status Word
    ; The Carry flag is restored to its original state
Interesting that it'd balk at quoting the Z80 ISA manual...given Zilog publishes it for free on their site. Also I do have to wonder what grey area older ISA manuals fall under. Many were published as trade books, although I don't know what the situation was with, say, buying an eval kit or something like a ICE or SBC, if one expected to get an ISA manual with it or not. I feel like I've read before that manuals included with products are fair game to distribute, but if it is a published book situation like that I don't know how that shakes out.
Topic drift I know but I do find it interesting that it refused to quote some technical manuals...
That doesn't make it free to quote. What does make it free to quote (at least at the level of a single sentence, usually much more) are the fair use provisions of copyright acts. On the other hand, I can see some paranoia about wanting to avoid legal troubles; even if a usage is clearly fair use, you can still be sued over it, and that can be expensive to defend. On the gripping hand, I suspect that that may just be a convenient excuse for them covering up an inability to generate actual quotes from texts it "knows."
And hilarious that the first response to a thread started to avoid topic drift in another thread is itself topic drift. :-) (But I don't mind.)
Given how lax the general situation seems to be with respecting copyrights, this also surprises me. What with the fact that these models are being trained on all sorts of folks' content with little to no consent, you'd figure it wouldn't be so touchy about it. Just another layer of weird.
In any case, I haven't really played with these technologies myself. A few coworkers will use things like Copilot, but I have seen multiple situations where they ask it some question and I can get them a reasonable, more intelligible answer before the bot does. I do slightly worry about falling behind the times...but if the times are being expected to use buggy stuff from chatbots rather than being a knowledgeable programmer...then I'm fine with getting off that bus and doing something else. Gardening is quite enjoyable and less likely to be taken away by computers, at least in that way...
It's a tool, nothing more. Often, the results are good, but frequently, the results are nonsense, as your examples show. So always verify.
The question is if it's more work to verify the result as opposed to working out the problem yourself.
I ran into a similar situation last year when asking ChatGPT to code a driver for a composite USB device using a specified library. Somehow, CGPT managed to write some code that looked reasonable, but then, on closer inspection, it was gibberish, with nonsense descriptors and references to nonexistent library files.
I note that CGPT now flatly refuses to code for long-gone architectures, such as IBM 7070. It used to spew out utter nonsense that was as similar to a 7070 as crabgrass was to a horse.
On the other hand, AI is a great economic stimulus to various semiconductor operations and the energy sector. Witness Bezos planning to put 4 nuclear power plants on the Columbia, near Richland, WA. I suspect that BillG's Terrapower won't be far behind. Naturally, there are gummint billions of free cash involved. I understand that Washington state is prepared with $3B,
Note that nukes are hideously expensive in the long run. So more sucking of the public money.
When they are running, they are pretty cheap, it's just that once they no longer run taking them apart is probably more expensive and time consuming then making them in the first place.
...and naturally, the US, unlike other countries, doesn't recycle its spent nuclear fuel. Too expensive, you see.
Expensive, produces small amounts of very toxic material (with a few hundred years shelf life), and what do you do with the weapons grade Plutonium you don't need.
Weapons grade? That is an argument against reprocessing that has been completely overblown, and is almost completely negated if instead of using old fashioned 1950’s tech light water reactors with separate breeders we used fundamentally better designs like the Integral Fast Reactor with onsite pyroprocessing. Reactors like this could provide a few centuries’ worth of power just by burning up all the spent fuel rods that are sitting in the swimming pools behind all our current generation reactors, and there’s almost zero risk of anyone making a bomb out of the stuff cycling through the reactors because:
A: you don’t need to ship it around, it all stays on-site, and
B: The plutonium in it isn’t nice tame 239, it’s a mix of really nasty isotopes that are extremely difficult to build a working bomb out of and would kill anyone trying to handle it.
IE, if you wanted to use an IFR to make nuclear bombs you’ll have to run it like an oldskool breeder reactor and build a PUREX plant to process the output, so, yeah, no point doing that when you can do the breeding just as easily in a pile of graphite that looks like something Saruman’s orcs could build. It’s still a thing outside the reach of a rogue state or an evil billionaire.
Nuclear doesn’t pencil out in the US today because a series of bad decisions based on irrational fear has limited us to laughably bad and obsolete generations-old technology. We could do better. That said… definitely not sure I trust crypto/AI tech bros to implement anything more safety critical than a water balloon.
Could the next person who wants to continue discussion of nuclear power please start a topic for it, and just post the link to that here?
I mentioned the topic only in passing....
That is correct.
...plans [for nuclear plants] to power that power-hungry AI.
Again, correct.
See the tie-in?
Indeed I do, and I was already aware of this.
All that said, I'm not sure what any of the above has to do with things. It has not changed that we have seven subsequent messages purely discussing nuclear power rather than AI, it's gone terribly off-topic for this thread, and we can solve this issue by continuing it in another thread.
Also, if you felt I was blaming you for any of this, I'm sorry about that; it was definitely not the intent. Your first aside on it was quite reasonable to include in your post; discussions just go off the rails sometimes and a new thread and link to it fixes this.
The company I work for has completely swallowed the ChatGPT Kool-Aid, and everyone has been ordered to install GitHub CoPilot in their IDEs, exercise it, and respond to opinion polls about how well we think it works.
Reading your story gave me flashbacks to a mildly frustrating “conversation” I had with it this week, when I ran into an issue working with the Openstack Client SDK; I’ll save the details, but broad scope I’ll just summarize my opinion of it like this: if you’re working on some relatively mundane task that doesn’t require a lot of thinking, sure, ask it, and it’ll probably give you a hunk of code that fits your needs about as well as if you’d searched StackExchange, did a copy-paste of the best answer, and spent a few minutes changing the variable names and otherwise hammering it into shape. It’s also pretty effective at acting as an enhanced auto-complete for structures like a series of switch statements…
But the Openstack problem revealed the big weakness: the quality of its answers degrade sharply as the amount of source material it has to reference goes down. Ask it to write you a “generic” BASH script or something it’s really good at that, millions of answers to for it to digest and copy, but ask it for help with something that’s slightly obscure and poorly documented and… no. It’s not better at RTFM-ing than a real person, at least one that’s capable of reading manuals. (Granted there are plenty of people who can’t, or at least won’t.) It “understood” broad scope that calls to the API would return dictionaries, but its suggestions for processing the attributes were full of hallucinations with regards to key names and other details. You can still save a *little* grunt work by accepting its suggestions as a template and correcting them based on reality deduced from some debugging print statements… but ultimately that’s about what you’d be doing with a Stackexchange copy-paste two years ago anyway.
And, the specifically frustrating bit, it was also completely unable to adapt when some code it suggested didn’t work because of an obscure-but-documented-if-you-dig-deep-enough problem with authentication dictionaries and token authentication . I mean, I get it, it’s an edge case, but it was hopeless at doing anything with descriptions of the error message that made sense (mostly it just repeated itself like a Dustin Hoffman character), and its one specific suggestion was just a flat out hallucination. I gave up and threw a “hey” at a real human I guessed might have seen the issue, and from their affirmative answer cooked up a workaround myself in about the time I’d wasted on the chat.
So, I dunno… *shrug*. It streamlines stealing code, and when its theft fits the task it’ll save you some time. But never ask it to logic anything out for you.
So, I just had a look at Clough42's video What I Learned from Letting AI Write My Microcontroller Code, and learned a few things.
His initial chat about architecture with ChatGPT seemed more of a "please confirm that what I want to do is the right thing," with him giving leading prompts and catching the usual errors. So that definitely does nothing to remove the need for a competent, experienced developer; the LLM is basically a more sophisticated rubber duck. (I personally find that simply writing up design documentation does a better job of this, since it makes me go through the work of explaining exactly what I'm doing and why, and I'm a far better critic of my work than an LLM.) And, of course, the LLM missed some obvious things that should be considered, such as looking at fixed point instead of floating point for real number calculations.
Speaking of critics, LLMs may be almost worse than useless at critiquing designs, given that current LLMs seem to be designed to go to great lengths to agree with the user, rather than challenge him on anything. But it did bring me to the realisation that there's one way in which these can be truly useful to programmers: "Write an explanation for my manager of why the thing I want to do is the right thing to do." (No smiley there; I'm quite serious.)
The next section shows one area where I've found LLMs to have a greater chance of being quickly helpful than a web search: giving hints to experienced developers about languages they don't know all that well. In his case it was, "How do I define enums in C++ so that they don't convert automatically to integers?" Though this is probably not all that great an example because a) you have to know enough about C++ to be able to ask the question, and b) once you know that much, simply looking up a quick tutorial on the web about enums in C and C++ does the trick, and I personally would probably do that anyway in order to better understand exactly what's happening in each case.
The rest of that section seems to be the LLM doing boilerplate code, kind of in the way an IDE does it except with more typing of long prompts to the LLM, and a greater need to check the results. (Github Copilot's autocomplete is apparently accurate about half the time.) He also demonstrates that you often enough do need to know the APIs well so you can tell it to use the one that it should have used but didn't. It's still helpful, but in part because C++ is a particularly verbose language. Is the auto-complete better than traditional IDEs? Sometimes, maybe? Is it worth the massive greater cost in CPU cycles? Hmm. My understanding is that, at $10/month, GitHub Copilot is pretty heavily subsidised. I wonder what it really costs, and whether people would be willing to pay the true cost of it.
When he gets on to asking it to generate a header file for the control definitions based on the definitions in a 4D Genie file I was curious to see if this would work better than a sed script. It was definitely faster to write up the prompt, and probably still even faster with two or three more rounds of prompting, but it turned into the so-often-seen usual rounds of arguing with the LLM and the LLM continuing to apologise for producing incorrect results and producing "corrected" ones that are still incorrect (and often exactly the same as the previous result!). I did have to laugh when at one point, in response to a request to include all the definitions rather than just some, it simply added a comment // Put additional definitions here to the end of the file.
Also amusing was his summary. He says that experienced coders who know what they're doing and are familiar with the APIs can use this to write a lot of code. (I think that whether one should be writing a lot of code is the real question one should be asking here, but I've not got much traction on that in 25 years of industry programming.) And otherwise?
If you're not an experienced programmer and your usual toolbox is Stack Overflow and a hammer, this is kind of like adding "running with scissors" to your repertoire.
Brief re: nuclear: it will never shake the fact that it was developed for weapons and power generation was a happy secondary effect. In theory nuclear power is great, in practice one must be wary of who its patrons are in bed with and whether safety or some other concern is their top priority.
An LLM in my mind operates as a sounding board but not an expert. Give it to an expert and they can probably wrangle some use out of the system. Give it to a novice, especially a gullible one, and it is a disaster waiting to happen. Part of expertise in subjects is knowing how to seek information, how to formulate questions and investigations, how to gather what references you even intend to study. An LLM given an abstract problem is going to give you a pretty abstract solution. An LLM given guardrails is a bit more likely to come to an agreeable answer because you can tell it where *not* to look, what *not* to consider. Saying "Write me a web server" is a lot different than saying "Write me an IEEE 1003.1-conformant daemon service in C which handles TCP/IP communication via the sockets protocol and interprets requests for resources from filesystem path <abc> encoded in the RFC 2616 HTTP/1.1 standard, using one thread for request buffering, one thread for response buffering, one thread for request handling, and mutex-protected shared memory buffers to communicate between threads."
However, we have also seen even when told to refer directly to a primary source, an LLM may take some coaxing to get the right interpretation. Still better than assuming the LLM knows the exact primary reference for a given standard or protocol. This isn't to say it's good btw, just to demonstrate how I think about it from the outside looking in. I have no interest in LLMs and refuse to play with them or feed them anything intentionally myself.
And how exactly are these techo-parrots ingesting these rather expensive per copy not anywhere officially for free standards?
I suspect they're not.
"I have no interest in LLMs and refuse to play with them or feed them anything intentionally myself."
Unfortunately, unless they are gluttons the techno-parrots eat whatever they want from bitsavers. If they become techo-pigs, their address range gets banned.
