jamesbeat
I'm currently building a Raspberry Pi based system for running all of my old home computer emulators.
I'm building it in a PC case and breaking out all the ports to the back of the case.
I eventually want a desktop style case, but I'm having a little trouble finding one at a sane price, so for now I'm using an ATX tower.
As I mentioned above, I have broken out the ports to the rear of the machine, so I have various blanking plates with VGA, DB-9 joystick, audio and usb ports mounted in them.
I also made a base board for all the components such as the Pi, a hub, joystick adapter etc, so that it fits into the case like a motherboard.
The idea is that when I get a different case, it will be a simple matter to unbolt everything and transfer it over.
I have noticed that a lot of the desktop cases that I like the look of seem to be the AT form factor.
This isn't a problem for my "motherboard', as it will be simple enough to trim it, add extra holes if needed etc.
It's been a long time since I last owned an AT case, and it just occurred to me that I have no idea whether the AT mounting system for cards is the same as ATX.
Will my ATX blanking plates fit in an AT case?
