billdeg
Technician
That won't work. Spinrite only works on recognizable partitions. If you can't read a drive with DOS you can't run Spinrite on it.
Sure it will, I have done it before with the version I have. It's on my website. The only thing is that you have to boot the computer with a known good DOS disk, then you run spinrite. I guess you could also try an Advanced Diagnostics disk to test the controller card.
