and if you have to desolder the original first... significantly greater risk of damage to the board.
I've cut in a little farther into the chip, but I don't see any pins yet!! I cut into another DS1287 with a Dremel a while back and never did get to the pins, even though I cut almost halfway into the pin. Can the exacto knife cut the pins or part of them off or am I just getting to scared about damaging the chip???
I'm looking at that page right now, unfortunately, the pictures and my chip don't match. It seems like you didn't have to cut in that far to get to the pins. For how far I've cut in, I should be seeing (at least) the top if not the full pin.There is a photo in the article I linked in my post above (Photo 2). Thats what you should see.
Tez
I now see a little piece of metal, near the middle of the spot where I have cut in. When I cut into one of these a while back. I ran into this metal that looked more like a metal lining.
Now, when I (hopefully) reach the pin, I need to cut a little behind it so I can solder the wire to it, right?
