Dave Farquhar
John C Dvorak mentioned an old scam in his PC Mag column this week. I think he's mis-remembering, but want to run it past some other people who were around in the BBS era. Here's the money quote:
Breaking this down, the best case scenario I can come up with is the following. The BBS would have to be running a non-Hayes compatible modem.
1. BBS sends +++ to send the caller's modem into command mode
2. BBS sends AT L0 M0 to turn off the speaker
3. BBS sends AT H to hang up the phone
4. BBS sends ATDT (phone number) to make your modem call Bulgaria
The problem is that step 3 precludes step 4. And I actually did some experiments in the 1980s, calling a friend's modem with a non-Hayes modem, to see if it would be possible to kick his modem into command mode remotely. He was running a BBS and wanted to see if that was possible. I wasn't able to do it. (His concern was a torqued-off user sending AT commands to mess with his modem configuration and knock him offline.)
But maybe Dvorak knows something I don't. I know there are people here who know lots of things I don't. So.... Was this scenario that he's describing possible?
I'm immediately reminded of the online scams that took place during the modem era of communications. You'd be given a number to call, and it would actually be some sort of scam. The local number would connect to a BBS of some sort which would send a code back to the modem to turn off the speaker, so you couldn't hear the modem disconnect and then redial a number in Bulgaria or some obscure island. You'd then be connected to a phone service that charged $100/minute for the connection. After racking up thousands and thousand of dollars in phone costs, you'd get the bill from your phone company for $30,000.
