Early scsi emulation help
Elektraglide
UK
Iv'e decided to write a Tektronix 4404 emulator so everyone can experience Smalltalk-80 on a 68010.
I've started with Brad Parkers amazing sun2 emulator as its 68010, b/w display, MMU. So roughly similar, but much more sophisticated than tek4404.
So far the emulator starts (yay), prints some diagnostics:
Pegasus
% Adr: 00
..and tests memory, tests ACIA and DUART, clears the MMU pte and now its ready to start the SCSI disk.
I see it writing some 1 byte commands in order:
cmd=0 => disassembly of the boot rom shows it expects 0x80 reply to continue
cmd=1 => ??
cmd=255 => disassembly of the boot rom shows its expecting this to do an IRQ_3. I have no idea why.
While I have been writing low level stuff for decades I have not a clue what I am doing and no idea how you drive (early) scsi.
(I have written and shipped pure m68k assembly video games in the distant past and thought I knew m68k, yet the whole SFC and DFC register stuff was totally new to me.. Embarrassing)
ANY thoughts, suggestions as to how to approach this would be most appreciated!
Cheers. Its 1985-ish
There are 2 memory-mapped i/io spaces called "scsi" (0x7be000) and "scsi bus register" (0x7bc000).
All the read/writes I see are to the "scsi" but is that scsi commands? Or some tek4404 protocol? There are certainly a lot of busy wait loops in the 68k assembler waiting for things to happen!
the 4404 uses a Xebec 1410 controller, which is SASI, not SCSI, and very much not SCSI Common Command Set
4404 uses as Adaptec 4000 chipset for the controller. The minimal docs for 4404 do talk a lot about SCSI - is that just sloppy language?
I made my code always fire an IRQ for every write and now I get past Device Not Found and get Device Not Ready.
can you dump the eprom on the adaptec? i'm really curious if they modified the firmware
which would mean it wouldn't match the adaptec docs
There are a few different levels required for this answer.
At the lowest level, a SCSI device is kind of intelligent. You send it commands (packets) and it response. The more common commands are read, write, seek, etc. The command packet structure evolved over the years so you have six byte, 10 bytes, and other variants of the packets. There are many other possible commands, some specialized, and not all used. You need a general model of a SCSI device that given an ID, read, or WRITE command generates results. The good news is that after the command gets to the device, it's a black box.
Then you need to model the controller. The controller is responsible for taking commands from the host (your OS) and translating them into SCSI commands for the device. At a really low level there are all sorts of bus transactions you can model, but the simple version is take an OS command and convert it to a SCSI command to be executed by a device. The controller will need to do things like keep the state of the current in-flight commands and possibly do some SCSI bus locking if you implement the more esoteric commands.
And then there is the host layer. Does the host form a structure in memory and then pass that to the controller? Is it in I/O space? What's the mechanism by which the controller interrupts the host when it is done?
Yes, its all in some mapped I/O space. And this will be an emulator, so I just need to decode enough to go fetch blocks from a file - not a physical scsi device.
The sequence I see is:
scsi(007be002) write <= 00
scsi(007be012) read 1
scsi(007be002) write <= 01
scsi(007be002) write <= ff
scsi(007be008) read 1
scsi(007be00c) read 1
Then some MMU setup
MMU(00780000) <= 20
VirtualMem: DISABLE
Write Map Table: ENABLE
PTE pid: 00
<clear 2k of PTEs>
MMU(00780000) <= 00
VirtualMem: DISABLE
Write Map Table: DISABLE
PTE pid: 00
XXX write VBR 0 @ pc 74068e
Then some writing to I/O mapped "scsi bus register" (presuming its an autoincrementing register) so is that 0x8007 or 0x0780? ie LSB,MSB or MSB,LSB
scsi_bus_address(007bc000) write <= 80
scsi_bus_address(007bc000) write <= 07
Then some more hitting the scsi I/O mapped
scsi(007be00a) write <= 07
scsi(007be004) write <= 00
scsi(007be006) write <= 00
scsi(007be018) write <= 00
scsi(007be01a) write <= 13
scsi(007be01c) write <= 88
scsi(007be002) write <= 09
I have the start of a Tektronix 4404 emulator here if you're interested in looking it over / getting ideas / grabbing anything. Sadly, I didn't make it very far, it's really skeletal. I did not actually implement very much of the SCSI stuff yet, so that won't be helpful to you, but there may be other useful things about the memory map in it.
Seth, your Rust emulator inspired me to start writing an emulator in C :ROFLMAO:
Most helpful.
I could not see in your code how you handle the ROM being mapped into all addresses at startup and no mention of FunctionCodes either. Tek4404 alternately writes to SFC & DFC (sys data / user data) as it strides up thru memory to find the maximum before a bus error - for now I've given my Tek4404 emulator 6M so it never fails :-)
I am slowly annotating the 68k boot code.
I am reasonably sure the:
...Is writing a 3 byte address of some sort (logical block?)
and
is a UNIT_READY cmd as its used at the top of many scsi functions.
Neat! Since I use Rust (mostly for embedded projects) I just tried building it on my FreeBSD workstation. Not only does it build, but it runs too:
I could not see in your code how you handle the ROM being mapped into all addresses at startup and no mention of FunctionCodes either. Tek4404 alternately writes to SFC & DFC (sys data / user data) as it strides up thru memory to find the maximum before a bus error - for now I've given my Tek4404 emulator 6M so it never fails :)
The ROM is mapped into RAM space by default at startup (0x000000 to 0x1fffff). This is turned off when the sound generator is initialized by writing to 0x788000. This is sort of documented in the service manual (http://www.bitsavers.org/pdf/tektro...em_Component-Level_Service_Manual_Jun1987.pdf ) on pages 2.1-54 through 2.1-56, but it seems like a weird choice to me!
It "runs", but it really is such a skeletal system that it isn't doing anything useful yet! :) I like Elektraglide's idea of using Brad Parker's Sun-2 emulator as a starting point, it makes a lot of sense.
I was sure I looked before, but I found a mame plugin for tek4404 that appears to have a scsi implementation!
Going to see if I can get it building.
Wow, nice catch! It really is a special style of writing in the service manual!
"So when it turns it (sound) off it also turns off the Mapping of the Boot ROM to everywhere in the system."
BTW Twylo, the tek440x MAME emulator contains a full keyboard mapping lookup if you need for your project.
FWIW, there were ACB-4000 variants that talked Atari "SCSI" as well; at least some (possibly all) of the Atari Megafile controllers for MFM drives, as well as some 3rd party units.
Atari SCSI = Atari ACSI? Many years ago, I designed a "wedge" board that fit between the ST ACSI connector and an OMTI SCSI controller for interfacing RLL ST506 drives. Used it for quite awhile before getting rid of the ST.
[Been working on the MAME Tektronix 4404 emulator to get it going - its an amazing piece of work].
re: SCSI/SASI, the emulator emulates a ncr5385 controller chip mapped at 0x7be000 - and it manages to read my known good disk image from a real Tektronix 4404 - mystery solved!
