I verified it IS still working for me; I had upgraded my raspberry pi 3 in my little mac portable system to a 4. I'm using the :: c-d syntax, it just works fine.
Are you sure your server and client version match?
Sorry for going away a bit from the original topic, but I see that you run a virtual floppy?
Is it something like; https://code.google.com/archive/p/xtideuniversalbios/wikis/SerialDrives.wiki
Pls point me in a good direction for a floppy emulator, so then I maybe do not need to reuse the few old 5.25" floppy disks I have left for just creating install / boot disks...
I'm kind of starting to rediscover these old computers and it seems a lot of convenient things been added since...
And I see that Trixter is writing in this tread, I must take the opportunity (even if only seen on you tube as I have no 8088 machine) - your demos are incredible!
I did a part of the "coding" for Pinball Fantasies (and Illusions) PC version back in the 1990s, but since then I have done other things and almost not touched any old computer... Though, I saved some stuff from back then, that now come up to the surface during some basement cleaning. Sadly I did throw away some CRTs, IBM computers and stuff that I really would like to have now, but it is 20 or more years ago... Anyway. I will set the machines on a physical network tonight to see if this fixes my problem, thanks for all good advises!
