shirsch
Today I set out to add another 256K of memory to a working M8067-KA memory board. After considerable study of the technical drawings and schematic it really looked as if the only difference between a KA and LA (512K) was the addition of 36 M2864 64Kx1 memory chips and the associated bypass caps. I checked all the new chips with a Retro chip tester and they passed. Problem is, the board still shows as being 256K (128KW). Has anyone done this mod themselves? I'm concerned I overlooked a jumper setting, but there don't appear to be any particular to the RAM size. The VMJA ECC/Parity test passes what's there, but seems oblivious to the added memory. There are two PROM chips on the board but the K and L variants call out the same DEC part number.
I'm a bit stumped. Anyone have thoughts?
