Pacific Northwest FA/FS: HP Vectra PSUs
Covers: Oregon and Washington
Chuck(G)
25k Member
Pacific Northwest, USA
Delivery Options
In Country Shipping or Local Pickup
I've got a bunch of the small HP Vectra PSUs, from the P1 through the P3 varieties. About half the size of a normal PSU, so not common. PM if interested and need specifics.
Yes, I did--turns out that it's connected to an on-board thermistor. I found that I was able to control the PSU fan with a simple pot across the connector lines. I'll get some dimensions. The P1 is a little interesting in that it's not an ATX type and has a separate connector for the +3.3v supply.
For those interested in the particulars:
.      Vectra P1 PSU.  6" W  x 5½" D x 3¼" H; Minebea Electronics, 160W,
        HP Part No. 0950-2998; 5x4 pin Molex +1 4pin 3.5" drive connector
        13 pin Molex single-row (PS1), 6 pin Molex single-row (PS2)
        +5/20A, +12/4.4A, +3.3/12A, -12/0.5A  -5/0.2A
        Power receptacle is on the 6x3½" side
2.      Vectra P2 PSU. 6" W x 4" D x 3¼" H; Delta DPS 16GB, 160W,
        HP Part No. 0950-3623, 5x4 pin Molex + 1 4 pin 3.5" drive connector
        20 pin ATX connector + 4 pin fan sensor
        +5/16A +3.3/16A +12/4A +5VSB/1.5A -12/0.5A -5/0.3A
        Power receptacle on the 6x3½" side
3.      Vectra VL P3 PSU. 4" W x 5½" D x 3¼" H; Delta DPS 125EB, 120W,
        HP Part No. 0950-3708, 4x4 pin Molex + 1 4 pin 3.5" drive connector
        20 pin ATX connector + 3 pin fan sensor +4pin for battery backup
        +5/15A +3.3/8A +12/4A +5VS/2A -12/0.5A -5/0.3A
        Power receptacle on the 4x3½" side
4.      Vectra VL P3 PSU. 4" W x 5½" D x 3¼" H; Delta DPS 125EB, 120W,
        HP Part No. 843032, 4x4 pin Molex + 1 4 pin 3.5" drive connector
These are all unusual in dimensions and probably difficult to replace.
I also have a couple of the old large AT (5170 style) power supplies; function unknown, but can check. Would not be surprised if recapping was needed, given the age.
Also a few of the older standard ATX style without the +12V CPU connector and 20 pin main connector. Power ratings vary from 200, 250 and 300W.
I have a Vectra VL in storage so if these are still available by the time I get to look at it, I'll post back whether any of yours are a match
I pretty much stuck with Vectras, right down to the C10. Just seemed to be a bit better constructed than the usual HP "home pc" stuff. Speaking of oddball, I do have a Compaq 460W PSU for the Compaq XW6000 workstation. Bigger than ATX--BTX perhaps. Has the usual 24 pin power connector but with totally different pinout. (I documented that some months ago).
I still have the vectra VL cases with more modern (AM3) motherboards. I managed to fit appropriate TFX PSUs in to provide the necessary power; it's not a perfect fit but good enough. The original HP Vectra PSUs are nobody's standard. Of course, number 1 is the real oddball, with a separate 3.3V plug. I hung onto the cases because they would fit a standard ATX motherboard and are the usual HP old-style beefy steel desktop (not minitower) cases. Gives me somewhere to put my coffee...
