Marty
Hi All;
Jnz, I would need to look at John's Homepage to be sure.. But, I think in His Video's they mostly would be stand alone for initial checkout.. But, Yes, You are right You would need to get the following for a Minimal System..
A motherBoard and Power Supply, At first You could use an old PC type of Power Supply, I keep my old ones for just this reason..
A Z-80 Cpu, later, You could get other type of processors..
A Memory Board, Anything from 2K to 2 Meg, would be enough to get You started, You could add more memory later..
A Serial card of some sort, preferably two ports..
"" How do I verify the operation of something like a Z80 CPU card without also configuring a memory card and SIO board? An oscilloscope? ""
A scope would be the top of the line, but at first Led's, or a Monitor or FrontPanel Board would work just as well..
"" Is there a standard metal component that can hold S-100 bus cards? ""
After you get a motherboard, You could then measure both Length and width and height and find something on the internet, that would fit what You have.. A plane Bare chassis Would be cheaper than one that has an Old name on it, like Altair, Imsai, etc.. And later, when funds are there You could get something with a name on it..
A Desk would be Ok, as long as its Not metal, I do alot here on my Wooden Kitchen Table..
Go look at my Links for my various machines, like my PDP 11/45 or my PDP 11/40 and Yes I have an Altair 8800 and my current project my PDP 8i Clone in/with wire-wrap sockets..
THANK YOU Marty
THANK YOU Marty
