I don't even care if you are running at 4.77Mhz - I'd just like some speed comparisons on any machines. I'm measuring with a 386-40 and I want to see what other people are getting on their machines kind of as a sanity check.
Mike
Mike
VCF Southwest | June, 2025 | University of Texas at Dallas |
VCF Southeast | June, 2025 | Atlanta, GA |
Results using the 3Mb ascii and binary files:
TXT put TXT get BIN put BIN get
LXFTP
- best 7.1 5.7 7.2 5.8
- ave. 7.4 6.0 7.3 5.8
FTP65
- best 11.2 6.0 11.1 20.9
- ave. 12.6 6.1 14.9 21.0
FTP70
- best (note 2) 6.1 (note 2) 21.0
- ave. 6.2 21.3
Well done! You've got good reason to be proud.mbbrutman: I'm getting about the same performance from a machine that has 1/3rd the clock speed. That makes me warm and fuzzy inside. ;-0
I'm looking forward to it!mbbrutman: I expect to have a usable beta version in a week or so.
I don't understand how you are getting faster puts than gets when my results are so strongly biased the other way. That was an ASCII file right? Also, I counted from "enter" to "return to prompt". Do you also get delays from transfer completion to "return to prompt"?Mike Chambers:
FTP v0.65 results:
GET = 921,600 bytes in 53.67 seconds ( 16.73 KB/s )
PUT = 921,600 bytes in 43.67 seconds ( 20.57 KB/s )
BTW: Try the LXFTP, it looks the same, it's got way more features, uses the same config and can be renamed for a straight drop in, etc. You'll like it.
ok, here is a speed test on my supersport 8088 running @ 8 MHz in turbo mode..
Real Computer
PUT 7.1 3.2
GET 5.5 3.7
Does this mean you got the ol' SS fixed? (Or are you using an external monitor)?
Sorry for the OT inquiry...
--T
Real Comp
ASCII put 6.7 4.8
ASCII get 4.8 3.6
BIN put 6.7 4.9
BIN get 5.0 3.1
It doesn't sound like there could be much lag there.mbbrutman: Hmm .. I don't know why the times are so far off on your machine. ... Time is measured in the program starting after the file open but before any data is sent or received. ...
Hmm, you know, that part is suspect. Linux often finds little chores to do before it does what its told. (Thats why I prefer DOS - it's obedientmbbrutman: Is your FTP server slow and taking a while to start the initial connection? That is time the user would perceive as part of the transfer, but actually is not.
I've never spent the big bucks on MSWin and associated programs (other than a second hand copy of DOS 6.2) because I made a concious decision not to go there. My software expenditures are almost nil, so when someone is writing software that might benefit me, and at no cost... I feel obliged to do what I can to help.mbbrutman: And thanks for checking it out so quickly - it is nice to get instand feedback.
So how does one do that?mbbrutman: "Here is what I have so far: * A command line interface that can be scripted by redirecting from STDIN ..."
