I got my hands on two more floppy drives out of a Osborne 1A that is in the serial number range of 248,XXX and the DD board out of the same computer.
The chassis plastic has a date of Jan 83.
I was hoping they were the newer MPI drives that are working great in my second Osborne, it's a 1A, but oddly they are a pair of Siemens drives.
The chips on the floppy mainboards have late 82 date codes, and the main boards are slightly different but have the same part number.
So I decided to service them, cleaned and oiled them and cleaned the read/write heads.
After that I decided to use the Gotek as my A drive and test the new to me drives both as B drives.
The A drive I removed the terminating resister and connected it it, nope it spins but errors out trying to access it or format.
I did the same with the other drive, it let me format but it gave only EEEEEEEEEEE's during the verification and one or more of the bearings are not happy.
So I decided to test the capacitors on the latest drives and the A drive has one maybe two shorted caps.
The B floppy board caps all tested good so I put the newer floppy circuit board on the orignial B drive and it works!!
