I have an XT clone here (ITT Xtra) which doesn't seem to want to read a floppy drive correctly. Unfortunately I can't find any documentation about the computer at all, so I don't know what any of the jumper settings do.
The drive I'm using is a 1.2MB 5.25" drive. The computer has what appears to be one floppy connector on the motherboard, and 2 on an expansion card (labelled J1 and J2). Obviously they're not all going to be for floppy drives, but the connection looks the same.
Plugging the drive into the one on the motherboard causes the motor in the drive to spin when the computer tries to boot, but the drive LED does not come on. It then gives the error 'drive not ready'.
Using J1 on the expansion card causes the motor to spin and the LED comes on, but gives the same error.
Using J2 does the same as the motherboard one - motor spins but no LED.
An XT clone would be compatible with a 1.2MB drive, wouldn't it? What would be causing this issue - jumper settings or something? If so, does anyone have any idea how I can set it up properly?
Thanks for any help.
