Found some Core memory by Fabri-Tek - trying to find what system & the manual
Ragooman
Pittsburgh,PA
I have some Core memory from a guy who worked at Four Phase. They're made by Fabri-Tek and he remembers these being used in some IBM system - the best he can remember. The really cool thing about this is that it's assembled in a way where it folds up. I have some pics at the links below. I'm hoping somebody might know what system this came from. I also have closeup pics of the board, serial, and part numbers too. Then maybe I can find a manual for this. With some luck and some hacking, I can then wire an interface to this for my homebrew PDP-8.
http://www.flickr.com/photos/ragooman/5788472143/in/photostream
http://www.flickr.com/photos/ragooman/5788471265/in/photostream
http://www.flickr.com/photos/ragooman/5789025174/in/photostream
http://www.flickr.com/photos/ragooman/5788469637/in/photostream
http://www.flickr.com/photos/ragooman/5788469117/in/photostream
http://www.flickr.com/photos/ragooman/5789023250/in/photostream
thanks !
=Dan
Whilst I am sure there is info on interfacing core elsewhere on the net, I know there are some articles in the ACC newletters, Volume-1, issues 2-5 which you can find here:-
http://www.smrcc.org.uk/members/g4ugm/acc.htm
Hope you find these usefull...
Yes, there's a few resources about building a memory controller circuit for Core memory.
I'm always open to more information like this.
Thanks for the tip !
g4ugm said:
Ypu might also want to ask on the Hercules-390 yahoo group if any one has any info. Its an emulation group but it has lots of ex (and current) IBM staff on it so some one might have more info..
http://tech.groups.yahoo.com/group/hercules-390/
thanks again for the tip
I'll try there too
Looking at this closer again, it's just a raw core memory card. I'm hoping to find some more info to help me pinpint all the connections on this. It would save time that to trace the connections manually. So then I can begin to make a memory controller for this.
=Dan
Maybe a bit off topic, but I stumbled on this interesting page (Nicolet Instrument was funded by Fabritek):
http://versci.com/1080proposal/index.html
It's the story of building a PDP-8 equivalent into a data acquisition system:
We did things the hard way. For example, we etched printed circuit boards in glassware liberated from the kitchen. I had access to a PDP-8 and I could have used it to write a cross assembler. Instead, I wrote an assembler for the 1080 using only pencil and paper. I used the switch register to get it into the computer. Then I used the teletype to create the source code for the assembler. That made it possible for the assembler to assemble itself. I must have been crazy. The assembler was then used to write an editor, a debugger, a floating point package including transcendental functions and a Cooley Tukey FFT. The hardest part of the 1080 project, the part that took the most time, was the magnetic core memory.
Dan,
Check out the 8/E Maintenance Manual Vol. 1 (processor options) for the excellent writeup on the MM8-E. I'm not sure if you have an Omnibus machine, but if you do, just copy the MM8-E.
Do you have to have core, or can you tolerate a semiconductor memory? If the latter and you have an omnibus machine, it's very easy to make your own memory.
Lou
Posted on another thread on this Board was a link to scanned and OCR'd early editions of Byte magazine: ftp://helpedia.com/pub/archive/temp/Byte/
Issue #11 has a focus on core memory and an article on how to use surplus core stacks by using SN75325 TTL (Texas Instruments Memory Core Driver chip), perhaps it could be useful in Dan's project.
Incidentally in Byte issue #3 on page 95 there is a ad for some Honeywell core memory that has a board that looks a somewhat like Dan's except it has two edge connectors not three. But it does have a similar form factor, and metal top edge I think...?
Steve.
It doesn't look like any of the core memory I saw when working on Univac mainframes. Univac II, UIII, 1107, 1106, 1108, 1050, 1004, 1001
Dan:
Just found this forum. In the early 70's I was the OEM Field Service Manager at Fabri-Tek. From the best of my knowledge, this memory module is not for a PDP anything. All the PDP 8's and 11's used an 8k memory module, P/N 256-0232-01. I looked at the pictures and can't identify this module.
JohnW
Fabri-Tek memory module
Dan:
JohnW
Dan:
JohnW
Hello John W.,
A friend recently posted in his blog about an old Fabri-Tek core memory module he had saved (decades ago) from some junk heap,
and I got interested in that company. There's an interesting PDF (company's advertising material from the sixties) available
at Internet Archive: TNM_Fabri-Tek_Incorporated_Company_Overview_and_Product_Line.pdf
I wonder what ever came of Fabri-TEK? Did it fold, or did it merge with some other company and changed its name?
Or did it change its core competence completely? There is a company called Fabri-Tek in Illinois now that manufactures PTFE-based tapes, kitchen utensils, and so on,
but I wonder whether it has anything to do with the original Fabri-TEK?
Best regards,
A. Kartturi
Bear in mind you're replying to a thread that's been inactive for over a decade. Some of the comments may be from people who no longer follow this forum.
The main reason I'm replying to this message is not my first part above), but to laugh at the (involuntary?) puns of a company that made folding memory actually fold, itself, and that a company whose core competency was making core memory.
On a more serious note, the US Patent and Trademark Office should have a history of any trademarks for the company name. If it ever went "Lapsed" or "Not renewed" it's likely a different company. That's for old marks like this one - in recent years, speculators purchase the trademarks / company names at bankruptcy auctions and then sell them to someone who wants to re-launch the brand / product. For example, Madewell clothing.
It's fairly easy to do magazine searches using the pdf indexes on bitsavers.
The company was having problems by 1979 when the core memory market went soft
and they were sold to CTS in 1982. They pivoted to modems and were still building them
in 1988
I also forgot they were in the connector business...
Not much was turning up in the 80's doing text body searches for "cts fabri-tek" on the IA
Thanks! And yes, core memory - core competency, that pun was indeed intended (and I have heard that one should never explain one's jokes). The term "folding memory" I hadn't heard of before, so in that case it was an unintended pun.
Finding and fabricating drivers and sense amps is going to be a real hassle, Dan. Not something that I'd want to go through.
I looked into this a long time ago and it involved long discontinued and genuinely rare TI 75xxx series IC’s. To do this one-off with discretes or even opamps would be heroic.
I'm pretty sure that's from a Honeywell 316. The ones I have in my machine are manufactured by Litton, not Fabri-Tek, but they look very similar indeed. On bitsavers you'll find the manuals for the H316 under computer control company/series16/h316
Back in the 80s we had an HP2100A that had 80K words of core.The Fabri-Tek memory was in a small enclosure with cable to card edge which plugged in to the 2100A.
The boards in the enclosure were solid not folding.
That's interesting. I presume that it connected as an I/O card (perhaps with software to act as a RAM disk) rather than in place of one of the normal 8K card-pairs in the memory subsystem since the HP 2100A address space is limited to 32K words. Sounds like an unusual peripheral device for that computer.
