Zippy Zapp
Hello,
After spending the past 2 days scouring everything I could on here and the internet looking for information on CMOS battery for this model I thought I would post in case someone here knows the answer.
I have a Gateway 4DX2-66 mini desktop. I have attached Pics so you can see the motherboard and connector. It has a 4 pin battery connector, 3 pins actually, since one is removed. I have the connector and the red and black wires but no battery that goes with it. This model has a Dallas DS12885 RTC, not the kind with a built in battery. According to the datasheet for that IC it looks like it expects 3V on the vbat input pin. So I am assuming the battery should be 3V too. But I don't like to assume and I don't want to guess and fry something.
I have seen some Gateways with the 66V tower motherboards use a Rayovac 4.5v pack. I don't remember seeing a large pack connected to my original. If it is 3V that is easy enough. A CR2032 battery should do the trick or a couple of AA's in a battery holder too. I verified that the pins are not receiving a charge so it is not a rechargeable battery.
Does anyone know for sure about the Battery?
Also does anyone have a PDF manual or scan available for this Gateway?
Thanks!
Battery Connector:
RTC Chip:
Motherboard:
Case:
History of this machine:
Has had 1 owner and is not yellowed. Has all original hardware including telepath modem, Ensoniq ISA sound card (Long card but looks like it needs caps as the solder pads look a little crusty.) Also original floppy, NEC CD and 750mb HD with original DOS/WFW3.11 install including the always cool gateway 2000 cow in space wallpapers. I will for sure image the drive just in case. I can verify the original hardware because Gateway always put Serial# and Date on labels on all their hardware of this era. Everything matches. HD, Floppy, sound and modem removed for these pics.
Thanks!
Battery Connector:
RTC Chip:
Motherboard:
Case:
