SunSpotter
The goal here is to keep my AT as "true blue" as possible, so no BIOS swaps, or removal of the original controller card if at all possible. And ultimately to get the 8" drive working alongside the original MFM HDD, a 3.5" FDD and a 5.25" FDD.
However, the original AT controller card only supports up to 3 total drives: either 2 FDDs and 1 HDD, or the opposite configuration. It's also worth noting that the particular 8" FDD that I have is a Vista Computer Co. V-1100 DSDD dual external drive. In effect meaning it's two drives in one enclosure, so with a stock AT I couldn't even use 1 conventional FDD alongside my 8" drive as far as I'm aware. The biggest problem though, is that while I already have all the necessary cabling, and an FDADAP 50-pin to 32-pin adaptor, I'm not sure what controller card I should be looking for.
I'm also going to throw it out there, that this drive is not to be mistaken for the V-1000 or V-1200, in case anyone looks it up. I'm not completely sure why but my particular drive just doesn't exist on the internet, in spite of the fact that information on its predecessor and successor models can be found.
Anyways, unless there's some trick I'm unaware of it seems like the original AT controller card is out of the question. And I have reason to believe the original card for the 8" drive itself wouldn't be AT compatible even if I could find it. I did try using a 16-bit IDE controller once, but it seemed to interfere with the functionality of the MFM HDD, even after I played around with the jumpers to avoid an I/O address conflict, so maybe it's a problem with IRQ? Either way, I'm stuck in a position where I'm not really sure what the best way to proceed is, or what controller card I should be looking for.
