hunterjwizzard
- Joined
- Mar 20, 2020
- Messages
- 2,715
Yes but its not nice to tell other people what they should and shout not want to do.If you just want to mount floppy disk images off a USB drive you don't need anything other than a USB port.
I know I know. It sounds stupid indeed.
What I am trying to find is a mixture of "(a usb floppy drive - the actual drive) + (a gotek-kind of thing to process floppy images - the 34-pin connection)" (read the + and - signs as you are doing math), without using a software solution. Most OSs and/or BIOS support a usb floppy drive (the "USB Mass Storage Class, UFI device, Floppy Device Unit" specs https://www.usb.org/sites/default/files/usbmass-ufi10.pdf).
To answer your question "What does a USB Gotek achieve that putting the same flash drive with disk images in a USB port would not?" I would say "none", if you do use a software to mount the floppy image. But that's what i am trying to avoid.
Again it sounds stupid. Some people don't mind running a floppy image mounting software, I personally do not like that.
Doesn't sound stupid to me at all. My whole hobby is about figuring out unusual ways to do things that scratch some itch. I am totally onboard with trying to find a good answer for you.
Did you look at the USB-to-Gotek or PCIe-to-SCSI Emulator options? I know the second one is pricey. Don't know how much you want to spend.
