Well... latest status update, Sir
I have the controller in my HeadStart LX-40. There's still some issues but you could say it works now (YAY!). Here's the deal:
I have version 0.11HS flashed now and that's the one that I can get working. I even get the menu at boot. Settings are 300h/CC00h otherwise it will either lock up the machine, show that the "RAM Buffer" is 0K in stead of 128K or it will show "Press ESC for boot menu" and after that it keeps looking for a disk in drive B: for some reason. Anyhoo, 300h/CC00h and it works with a 40GB Maxtor harddisk connected, I even FDISKed a 40MB partition and can boot from that.
Issue 1: When I use a CF card on an adapter, the card is found (although, no ID string), I can also FDISK a 40Meg partition... but after a reboot the partition is gone.
Issue 2: At the first boot of the PC, let's say when the harddisk hasn't spun up yet, the BIOS shows no drive installed for drive 0 and drive 1. If I CTRL+ALT+DEL, so a reboot without power loss, then the harddisk is detected as a Maxtor and everything works (otherwise, logically, I get no harddisk). The CF doesn't have this problem BTW (although it's erased after a reboot, but since it's ready in a short time I guess this is successfully polled at boot??). Since I've ordered 2 64MB DOMs (Disk On Module) that I plan on using, I guess this won't be a problem... I just hope those aren't loosing the partition after a reboot (soft or hard, as the CF does).
Issue 2: WHen I use the v1.1.5 BIOS, I can't use anything at all, no disks are found, the CF won't work either. No menu shows at boot, and when booting the boot screen stays on screen for about 30secs and then it will beep and continue with reading drive A. I can see the BIOS with debug at CC00 but no harddisk/CF.
