rebeltaz
At a HamFest this weekend I picked up an Atari 800 system with a disk drive and ham radio interface box, a Garmin Ique 3600 GPS/Palm (I know, not technically vintage but obsolete nevertheless) and a Heathkit ET-3400 trainer. The guy had four, but I only bought one - the most complete. The other three were missing ROM chips, keys and a whole host of other necessities.
The only thing that I can tell this trainer is missing (I haven't delved into it that deeply yet) is the two RAM ICs - IC14 and IC15. The manual (which I found online) shows that these are supposed to be 443-721 ICs with 2112-2 as an allowable substitute. They're shown to be 256x4 SRAM chips. I cannot find a datasheet or even pinouts on these chips anywhere. I did happen to write down the numbers on the chips that were in the other trainers there - I figured I could get the chips anywhere. Wrong. Anyway, the chips that were in those units were not the same numbers. Two trainers had 443-764 chips. These come up with the numbers 2114, 4045 and 6614 as acceptable substitutes. These are 1kx4 SRAM ICs. The other trainer there had a TMS2114-45NL IC, which I am assuming is the same as the 2114.
Since I cannot find pinouts on the 2112 and I don't know that much about ancient RAM, I don't know if the 2114 can substitute for the 2112 or not. I think I can find the 2114, but the 2112 seems to be a lost cause, unless someone here might happen to have one (or four) up there sleeve?
Thanks....
Thanks....
