Possibly a printer; those ROMs might be Postscript.
Unfortunately, they are soldered to the board.Dumping the eproms might yield some useful strings
Nope, his marking SN7406 and SP8404 (74LS08?), also I don't see USART IC on the boardI can't tell from the picture if there are RS232 driver/receivers on the connector in the lower right.
The upper ones look like they are driving a peripheral interface
the other thing is the board has a lot of eprom, but not much ram which wouldn't make sense for a laser printer
the eproms don't seem to have any text strings in them
Not from Xerox in 1983 with an 8085 processor
It was just a wild guess; I scrapped a printer years ago (Xerox IIRC, could have been NEC) with a similar size board and a daughterboard with 8 or 10 EPROMs containing the Postscript interpreter.
Both are most likely custom parts.
Good luck in finding datasheets.
You're right of course, it had a 68000 and was probably a NEC after all. Should have looked more closely but that ROM board looked very similar.in that time frame Adobe only had 68000 Postscript, and Xerox would NEVER have used it, since they had their own horse in the race (Interscript)
