Getting in and out of the old fifteen hundred series systems is a challenge if you don’t know the secrets! Like it says above, pop the two black feet covers in the back of the system and there will be a screw under each. I have found that if you back them out about a quarter inch and the tap the screwdriver it will pop the back housing top out so you can then remove the screws and then the cover.
The display will then flop over out of its hinges but watch out being some displays have a ground wire on the opposite side of all the screen wires.
With the display you can then lift the plastic panel around the keyboard, the back side is louse but the front is held by two snap in clips on the bottom chassis.
Once the plastic panel over the keyboard is removed you will then see the 256 Kb SIPPS, just like SIMS but with wire legs into the mother board.
Once you pop the back cover you can see the power supply, screen power supply and drive system. You will have a floppy drive (720K) or an internal Hard Drive depending on the model.
If you have the floppy I can send you a formatted GRiD DOS disk although you can also use any old DOS disk you have, I have run 3.3 and 5.0 with no issues but the GRiD DOS has several files unlike to the species that allow you to do things like use the internal modem if it’s installed.
What color is the display? There are three different displays with a poor LCD where the florescent tubes are always blown. A red gas plasma display that’s monochrome only and the Yellow plasma display that was only on the military secure tempested systems.
I still have several around the shop and reading your stuff inspires me to go back and maybe play with them.
Maybe even do a video on how to disassemble and put one back together! If you want to see what they look like with a yellow plasma display I have one being used as a terminal with an older computer on YouTube at:
https://www.youtube.com/watch?v=kJdTduulvAQ
That’s a gridcase 3 that was the model before your 1520 but that’s what the yellow tempested display looks like.
Good Luck!
