Yep. And don't get me started on wire nuts. WTF?!!! Did you know they're not legal in England? It's all barrier strip (aka choc block) over there. First time I ever saw them was when we moved here and I was like "Well, this hardly looks safe or professional. What is this barbarism? We put a man on the Moon for Goodness' sake!!!"
Well, to be fair, the US-Canada standard wiring topology is radial, as opposed the UK "ring mains" topology. Huge amount of difference. Lighting circuits are usually 120V 15A, while utility is 20A. Substantially less power than the UK standard. There's nothing wrong with "wire nuts" if done correctly--and that would seem to be obvious, but it's not. It's surprising how many people think that twisting the wires together before applying the wire nut is the "correct" way--it's not. Wires are supposed to be straight, with the nut doing the twisting--this ensures good contact all around.
When wiring ground lines, I use a crimp sleeve and follow with solder to join conductors. I like my grounds noiseless.
The old grease-filled "purple twister" wire nuts for joining copper to aluminum is slowly giving way to special MOLE connectors (you need a very expensive tool for them) or Alumicon (screw-type terminal strip) joints. Aluminum is still used for high-current applications such as ovens and ranges in the US--and it will be a very long time before it's gone. Fortunately, stranded aluminum behaves better with age than solid. It's still a good idea if you've got aluminum wiring to pop the cover panel off the breaker box and tighten up the connections every couple of years.
I just had a new heat pump installed, replacing my 24-year old unit. Power distribution was from a nearby breaker panel using stranded aluminum. The electrical contractor looked at the effort of adding an external junction box to the unit and connecting to the unit's copper using MOLEs and decided that it was cheaper and easier to rip out the aluminum and run copper right from the breaker box. I can't say that I disagreed with him. Since the HVAC contractor was doing the installation, it made no difference in the final price.
